Posted
Simulation du service Meteo Norvegien pour demain:
http://met.no/filestore/Screenshot-2010-04-16-11.jpg
La bas, l'espace aerien controllé est fermé, mais des vols VFR dans les zones G toleré aux risques et perils du pilote.
Bons vols, Nils "ES"
  • Replies 45
  • Created
  • Last Reply
Top Posters In This Topic
Posted
Today, Thursday 15 April, as from 4.30 pm, the entire Belgian airspace will be closed for an undetermined period of time because of an ash cloud resulting from the volcanic eruption in Iceland and that will be flying over Belgium. This means that IFR flights (Instruments Flight Rules), landings and take-offs will no longer be authorized in the Belgian airspace. You can get more information on the flights from or to Belgium with the airport operators.
Belgocontrol ensures the safety of air navigation in the Belgian airspace. Belgocontrol experts decided this Thursday morning that the safety conditions for air navigation in Belgium would no longer be met as from this Thursday afternoon. Besides the visibility matter, ashes can indeed damage the aircraft engines. Belgocontrol informed the State Secretary for Mobility, Etienne Schouppe, about this. He decided to close the northwest part of the Belgian airspace as from 2.30 pm and the entire airspace as from 4.30 pm. The decision to reopen the airspace will be taken by the State Secretary as soon as the safety conditions will be met again. Till further notice the airspace will be closed for IFR flights until Friday 16 April, 4.00 pm. This measure might be prolonged.
VFR operators should exercise extreme caution and must assure themselves that their intended flight can be conducted in a safe manner before flying.
Posted
Bon, c'est même barré pour les VFR, d'après cette NOTAM:
A698/2010
Valid from : 15/04/2010 15:02 Until : 16/04/2010 16:00 EST
Text : DUE TO SIGNIFICANT VOLCANIC ACTIVITY FROM VOLCANO EYJAFJOLL 1702-02 PSN 6337.5N01936.4W. OPERATORS ARE ADVISED TO MONITOR EB SIGMET WITH REFERENCE TO VOLCANIC ASH. AIRCRAFT OPERATORS ARE ADVISED IN ACCORDANCE WITH ICAO REGULATIONS. ATC UNITS CANNOT ISSUE IFR CLEARANCES TO TRAFFIC IN AREAS AFFECTED BY OR FORECAST TO BE AFFECTED BY THE VOLCANIC ASH CLOUD. OPERATORS ARE ADVISED THAT AFFECTED AREAS ARE CLOSED FOR VFR FLIGHTS.5029N00417E999
Lower limit: SFC Upper limit: FL245
Mais quelles sont les "zones affectées"? Le SIGMET EBBU ne donne guère de détails (juste une ligne de progression du front de cendres).
Posted (edited)
Avec ces conditions de NE, au taff on a observé des niveaux fortement en hausse en poussières fines (dégradation de la qualité de l'air), cause à effet (je ne pense pas) ? Je ne distingue pas bien l'échelle et la zone couverte par la carte postée plus haut... Edited by mick49
Posted
Rouen est fermé pour l'occasion...
Vous avez du entendre les infos mais on sait jamais :)
Tous les aéroports du Nord de la France son fermés jusqu'à au moins 10h demain matin.. Et s'organiseront suivant les évolutions MTO.
En espérant qu'il n'y ai pas d'accidents.
Bonne soirée.
"Les pilotes se moquent de marcher. Ce qui les motive, c'est de pouvoir voler."
Posted
Il y a des NOTAM pour Haguenau, Strasbourg, Sarreguemines et Sarrebourg...
Nombre de NOTAM : 6
LFSH HAGUENAU
LFFA-D2852/10
A ) LFSH HAGUENAU
B ) 2010 Apr 15 21:03 C) 2010 Apr 16 12:00
E ) AERODROME FERME A TOUS TRAFIC CAUSE CENDRES VOLCANIQUES)
LFGU SARREGUEMINES NEUNKIRCH
LFFA-D2578/10
A ) LFGU SARREGUEMINES NEUNKIRCH
B ) 2010 Apr 14 05:00 C) 2010 May 21 08:00
D ) MON 0800-1000 1100-1500
TUE WED THU 0500-1000 1100-1500
FRI 0500-0800
E) AERODROME RESERVE AUX AERONEFS BASES
LFFA-D2904/10
B ) 2010 Apr 16 10:12 C) 2010 Apr 16 18:00
E ) AERODROME FERME EN RAISON DE L ACTIVITE DU VOLCAN EYJAFOLL
LFGT SARREBOURG BUHL
LFFA-D1630/10
A ) LFGT SARREBOURG BUHL
B ) 2010 Mar 08 15:16 C) 2010 Jun 30 23:59
E ) 2 GRUES ERIGEES, HOPITAL HELISURFACE SARREBOURG :
PSN : 484344N - 0070308E
HAUTEUR : 36M
BALISAGE : JOUR ET NUIT
LFFA-D2849/10
B ) 2010 Apr 15 21:02 C) 2010 Apr 16 12:00
LFGC STRASBOURG NEUHOF
LFFA-D2854/10
A ) LFGC STRASBOURG NEUHOF
B ) 2010 Apr 15 21:04 C) 2010 Apr 16 12:00
Posted (edited)
Nombre de NOTAM : 6
LFSH HAGUENAU
LFFA-D2852/10
A ) LFSH HAGUENAU
LFFA-D2578/10
FRI 0500-0800
LFFA-D2904/10
LFFA-D1630/10
HAUTEUR : 36M
LFFA-D2849/10
LFFA-D2854/10
c'est un peu dommage pour ceux qui parten au treuil... il n'y a pas de conséquences ?
Edited by PRZ
Posted
Le dernier alerte du Met Office UK:
http://www.metoffice.gov.uk/aviation/vaac/data/VAG_1271417376.png
Un interdiction total de vol pour le VFR me parait exaggere, car les activites de sport aeriens sont punis. Par contre, peut-etre demain sera la journee pour se vacher au Satolas ou Cointrin... :)
Posted (edited)
Oui, si on reprend ta première source :
http://images.meteociel.fr/im/3952/vano_mlu4.jpg
Edited by CPT
Posted
Une question peut être idiote mais quand je lis les Notams, ils parlent d'aerodromes mais pas de CTR ou autres zones. Donc est ce qu'un terrain non controlé peut ouvrir? (par exemple chérence ou falaise qui sont près de chez nous).
Posted (edited)
Pas réussie à savoir (pas eu mon père au tel) mais bon on avait pas de notam quand j'ai regardé ce matin!et puis le nuage est à 6000m!Suffit de regarder la netcoupe dans la soirée pour voir si JPP a volé!!Par contre notam avec fermeture de piste dans la semaine du 26 avril au 2 mai. Donc pour les gens de Rouen et Beynes faite attention!
Vincent P
Edit: autant pour moi je viens de regarder il y a bien un notam pour Chérence jusque 6h demain matin.Il était a partir de 12h23 donc pas vu ce matin.
Edited by Junior
Posted
merci de l'info vincent. Au moins j'aurais essayé.
Dommage car avec le treuil ça aurait été sympa de venir vous voir. C'est pas ce WE que je vais étouffer la turbine du twin :)
Pour le moment rouen fermé jusqu'a 8h00 locale. Ca sent pas bon pour le WE au vu des dernieres info...:( on aurait du rester dans les alpes!!
Posted
Ce soir en région parisienne il n'y a plus que Bailleau et Buno d'ouvert, normal c'est pour la rime: il y fait toujours beau!
Posted (edited)
Ça doit être le risque d'étouffement des moteurs des planeurs ou des treuils électriques par les cendres qui fait fermer ces aérodromes réservés aux planeurs. D'ailleurs comme les planeurs évoluent dans la couche convective qui est complètement brassée du sol au plafond de convection par cette convection, il faut également interdire la circulation des véhicules à moteur au sol. N'oublions pas que le principe de précaution est inscrit dans la Constitution. Edited by Robert Ehrlich
Posted
Bailleau ouvert alors que Chartres fermer?
On peut m'expliquer?
Vincent P
Posted
Vincent P
Moret ouvert
Posted
Vincent P
Moret ouvert
Sarrebourg LFGT ouvert
Ventus CT D-KBJF JF
"Dans le ciel,on est à l'abri de la vie, de ses bassesses, de ses chagrins, on se sent pur et hors d'atteinte".
Antoine de Saint-Exupery
I FLY WITH
Posted
Ça marche même plus pour consulter les notams!
doit y avoir trop de monde!
Vincent P
En Suisse, on ne fait pas de détail : TOUT L'ESPACE AERIEN EST FERME AU MOINS JUSQU'A 18 HEURES
Ca nous évitera de devoir repolir nos bords d'attaque...
JPH
Posted
JPH
Sauf pour des vols VFR...
Bert
Posted
Pour l'instant (12h45 local) pas de notam pour Chérence, Beynes, Chartres et Dreux par contre Rouen jusque 18h UTC. Si ca continue demain Arnaud vient au terrain!
Vincent P
Posted
En plus la page du SIA pour les NOTAM est en carafe "due à un problème technique ou une surcharge".
Tu m'étonnes, ils n'ont jamais du être sollicités comme ça.
Sinon OK pour demain à Chérence pour moi, je vais aller vérifier les crochets treuil :-p
  • Create New...
